Page 3 of 3
Re: 64 bit version?
Posted: 14 Jul 2010, 05:33
by vld
sure...here's an easy one for you. Install 7zip and let me know how your right click functions work within Salamander.
Re: 64 bit version?
Posted: 14 Jul 2010, 05:35
by kbirger
I found your post on that. that's actually 7Zip's fault. Here's an easy one. Install WinRAR, which does it right, and let me know how your right click function works. Also, iirc, 7zip worked fine for me (just don't like it).
TBH, you probably don't need it since you can just use the plugins.
Re: 64 bit version?
Posted: 14 Jul 2010, 23:57
by Ether
The problem doesn't lie directly within Salamander, but in the way that Windows provides for it (WOW64). For a calculator, or mail client, or any other "dumb" application, it doesn't matter, but when you use a file manager (with a registry editor built in), you expect to have control over things and you hit the issues quite soon. Some of the most obvious:
  • File System Redirection: Windows doesn't show all the directories as they are on the disk; namely %systemroot%\system32 -> %systemroot%\syswow64.
  • Registry Redirection: HKLM\Software -> HKLM\Software\Wow6432Node.
  • DLLs: the DLLs loaded within a 32-bit application must be also 32-bit, thus none of 64-bit shell extensions (e.g. context menu handlers) are accessible in the application.
Re: 64 bit version?
Posted: 14 Sep 2011, 02:37
by tody
zarevak wrote:Just to remind you: You can use TortoiseSVN/TortoiseCVS/... in Altap Salamander without any problems by installing 32-bit and 64-bit versions at the same time. Altap Salamander (and other 32-bit applications) will use the 32-bit TortoiseSVN and rest of the system will use the 64-bit version. This is fully supported solution by both Microsoft and TortoiseXXX developers ;)
That's unfortunately not working for all TortoiseXXX products! In contrast to Tortoise SVN 32bit, TortoiseHG 32bit won't install on a 64bit system! :-(
Re:
Posted: 25 Jul 2012, 23:09
by Lazarus
Lazarus wrote:.... please please please make this into next update. I'd even pay again for this feature. :)
Ahhh, my prayers got attention, just looked here after long time. Thanks, god of Altap! :mrgreen:
Now stop arguing and take my money ... make that thing final. :D
Re: Re:
Posted: 16 May 2014, 23:22
by Lazarus
Now this took a long way, maybe my prayers would've been heared faster if i just believed in god. :wink:
Now i pray for a Linux version.
Re: 64 bit version?
Posted: 27 May 2014, 20:50
by Yuriy
Jan Rysavy, could you please tell the difference between x86 and x64 versions of Altap Salamander in simple words and put it somewhere on this site written in big letters? :)
I was able to find only one paragraph about that here, but that was located quite deep in 'Support' section. I think that extending it and putting it closer to surface on 'Features' or 'Purchase' would be better, so everyone could just understand why there are two versions available and which one he or she should actually install.
Re: 64 bit version?
Posted: 27 May 2014, 21:22
Good idea. What about some x86/x64 FAQ directly on Download page?
Re: 64 bit version?
Posted: 28 May 2014, 04:44
by Yuriy
Yes, that would be nice!
Re: 64 bit version?
Posted: 29 May 2014, 00:20
by Ether
While we're on the download page... It seems like the system requirements section is suggesting that Windows 2000 has a 64-bit version. :) I assume the mini-FAQ will resolve that.
Any PC running Microsoft Windows 8.1, 8, 7, Vista, XP, or 2000 (both 32-bit and 64-bit versions).
Re: 64 bit version?
Posted: 30 May 2014, 17:45
Yuriy wrote:Yes, that would be nice!
See http://www.altap.cz/salamander/downloads/
Ether, I ignored this fact to save some space :)
Re: 64 bit version?
Posted: 30 May 2014, 18:13
by Yuriy
Thanks, everything is clear now!
