Posted: 04 Jul 2006, 21:45
hi...
after the first time this safetywindow appears my pc(amd) wont shut down completely anymore (poweroff). it was the first time i saw the "now u can turn ur pc off" message in w2k.
but it wont return to normal shutdown&poweroff anymore. how can i revert this? besides the dont-show-this-anymore-checkbox wont work 4 me. i had to turn it off in configscreen.
suggestion:
split the cfg files in configscreen options (save on apply/ok) like colors, history etc. and exit/runtime options (save on close/shutdown) like last used drive/path in panel
thx 4 listening
suggestion:
thx 4 listening
