ChineseSimplified version of Altap Salamander 3.0
Forum rules
Michael Lu
Re: ChineseSimplified version of Altap Salamander 3.0
Post by Michael Lu »
Jan Rysavy wrote:How much is Salamander usable with Simplified Chinese Windows?
We really need to convert code to Unicode for proper support.
The usableness is nothing to do with the language of Windows. It's completely usable.
I'm interested in file managers like Norton Commander. So I'm glad to make translation for Altap Salamander.
Is there any reason to use Simplified Chinese instead of Traditional? Any technical limitations? Are Simplified Chinese software translations more common?
Michael Lu
Jan Rysavy wrote:Is there any reason to use Simplified Chinese instead of Traditional? Any technical limitations? Are Simplified Chinese software translations more common?
As I know, S.Chinese is mainly used in Chinese Mainland and T.Chinese is mainly in HongKong and TaiWan. No technical limitations.
You can see http://en.wikipedia.org/wiki/Simplified_Chinese for details.
Michael Lu
FTP plugin is finished.
ftp.zip
(43.09 KiB) Downloaded 1955 times
Great! You have translated two biggest modules. I believe 2/3 of work is done.
Michael Lu
ZIP and pictview
zip and pictview.zip
(42.3 KiB) Downloaded 2006 times
Both seem to be OK, thanks!
Michael Lu
encrypt plugin. Validated.
encrypt_validated.zip
(12.59 KiB) Downloaded 1979 times
Michael Lu
file compare plugin
filecomp_validated.zip
(8.32 KiB) Downloaded 1886 times
OK, thanks, I got it.
Michael Lu
Finally, all modules are finished! The slt files uploaded.
slt.zip
(143.91 KiB) Downloaded 2015 times
Great, I'll look at it and prepare it for next version.
