Kris wrote:
I want the focus on the command line and then it should scroll through the history.
just note: do you know that you can roll out any drop down list by using ALT+Down? It is default behaviour of the operating system gui.
Hi Ino,
Sorry but I do not quite understand what you mean by that, sorry !
If you could re-explain I would appreciate it!!
Cheers,
Kris
I meant that once you reach the Command Line by CTRL+TAB you can scroll items in the command history by CTRL+ARROW UP/DOWN and/or you can open the list of command history by ALT+ARROW DOWN and then navigate siply by arrows UP/DOWN.
Thank you for taking the time!
Yeah I am aware of this, I was just asking if it was possible to avoid having to gain focus on the command line first as you would not have to with many other NC clones.
