Setting of Altaptrl
Forum rules
Re: Setting of Altaptrl
ADB wrote:Well, it works finally.
Jan has forgotten to give you french.slg files in bin directory, I have attached all files and directories created by makelang.js in 2.53a version plus recommended set of batches in projects\french directory. You can check if you have them all.
ADB wrote:1) should I (re)install Java (where to find it anyway) to make works the js script and avoid to copy all english.slg to french.slg for each module?
I have no idea. You can translate current version and then it will be a part of Altap Translator package, so you will not need to run makelang.js anymore, so I recommend not to solve this problem.
ADB wrote:2) why there is no Search&Replace function to replace any string by another ?
We have bad experience with mass replace, so we have not added it. If you want to use it you still have a chance: export translation to .slt file (Ctrl+D key - see menu File), replace all needed strings .slt file in Notepad or other UTF8 text file editor, import translation back from .slt file (Ctrl+M). If you want to do it for all modules, you can use batches !export_slt.bat and !import_slt.bat in projects\french directory.
french2.rar
(128.09 KiB) Downloaded 2423 times
ADB
Post by ADB »
Fine. Thks.
But I think I had'nt access to this profile items (or I should change my glasses)
ADB
Arnaud Dupin de Beyssat
ADB wrote:But I think I had'nt access to this profile items (or I should change my glasses)
I'm not sure with it, I can change it in my profile, but maybe you cannot, I really don't know. That's why I changed it for you. ;-)
Tomas Kopal
Post by Tomas Kopal »
ADB wrote:Fine. Thks.
ADB
You can find it in User Control Panel->Profile->Edit account settings. Let me know if you have any problems accessing this area.
ADB
Post by ADB »
Well, I come back :)
So, I still have the same problems with Windows Sxripting so makelang.js doesn't work for me.
Could you send me a file with all 2.54 version plugin for French (possibly the respective slg files too).
Thks
Great news! I have sent you email with download link for Altap Translator with French project prepared for translation.
