Page 2 of 2
Re: Delay after every file operation
Posted: 17 Dec 2009, 14:20
by Tim
Jan Rysavy wrote:Could you please test older versions? (Install it to some temporary directory.)
AS 2.51: ftp://ftp.altap.cz/pub/altap/salamand/as251.exe
AS 2.5: ftp://ftp.altap.cz/pub/altap/salamand/as25.exe
Thanks for the links, Jan.
Will test these versions tomorrow!
Posted: 17 Dec 2009, 14:22
by Tim
SelfMan wrote:What OS are you on? Which version of ESET Antivirus/ESS do you have?
Are you using any programs with shell extensions like TortoiseCVS/SVN?
(1) Win XP Pro
(2) ESET NOD 32 AV 4.0.474.0
(3) No
Posted: 17 Dec 2009, 14:26
by Tim
Just tested.
Same delay problems with 2.5 and 2.51.
Grrrrr ...
Posted: 17 Dec 2009, 14:32
by Raptor
Maybe you can post some "system scan" log - for example from HijackThis to check it. Maybe there is just running some wrong process.
So it must be related to some software you installed or updated recently, because you didn't notice such delays before?
Posted: 18 Dec 2009, 09:23
by Tim
Jan Rysavy wrote:So it must be related to some software you installed or updated recently, because you didn't notice such delays before?
I'm afraid so.
Thanks for all your help.
Cheers
Tim
Posted: 18 Dec 2009, 10:18
Tim, if you will be able to find the delay reason, please let us know. It doesn't look like common problem according to this forum (only a few users are reporting this problem).
Posted: 18 Dec 2009, 10:37
by Tim
Jan Rysavy wrote:Tim, if you will be able to find the delay reason, please let us know. It doesn't look like common problem according to this forum (only a few users are reporting this problem).
Of course I will!
Ahoj
Tim
Posted: 21 Dec 2009, 10:32
by Tim
Looks like my system is the culprit.
When I turn on my computer the delay is hardly noticeable.
In the afternoon, the delay gets longer.
Seems I'm working too much! :o)
Cheers
Tim
Posted: 21 Dec 2009, 18:12
by vld
maybe your system is getting hot.
