Total Commander Proxy Plugin
Klettermaxe
Post by Klettermaxe »
Thanks for this plugin. :D
I use it with the TC Canon camera plugin (Powershot A95).
Copy time for 24 files of 50.538.267 bytes total is 1:50, approx. 459 kB/s. Not too bad for a real-life USB 1.1 connection. The 'Microsoft Scanner and Camera Wizard' is faster (1:30, both in advanced user's mode and in standard mode) but I love the system integration of my camera that your plugin provides.
For copying lots of files I use a cardreader anyway.
k0nelupy
Post by k0nelupy »
TC CanonCam Plugin:
Cancel in F5, F6 in TC ending operation after actual file transfer complete.
Cancel in AS do nothing - transfer continue
speed in TC and AS is same
manison
Post by manison »
k0nelupy wrote:TC CanonCam Plugin:
OK, I think I know where the problem is. I'll fix it. Thanks for the report.
Thank you for the plugin, it was a very good idea. Now I can throw TC into the shedder. (I so didn't like the behaviour, that when TC starts for the first time, you have to maximize it for yourself AND you have to save that setting :x ).
rimbulumbos
Post by rimbulumbos »
I so didn't like the behaviour, that when TC starts for the first time, you have to maximize it for yourself AND you have to save that setting Mad ).
WOW. I´m agree, It is a GREAT problem :shock:
Croog
Post by Croog »
This plugin is really good idea! :) I tested it with NokiaFS plugin and implemented functions works fine. (Only cancelling is problem here too.) I hope, you will add copy/move to other direction and delete functions soon.
Thanks for developing this plugin!
manison
Post by manison »
Croog wrote:This plugin is really good idea! :) I tested it with NokiaFS plugin and implemented functions works fine. (Only cancelling is problem here too.) I hope, you will add copy/move to other direction and delete functions soon.
Thanks for the feedback. I have fixed the copy/move cancellation problem for the next version of the plugin. I'm implementing transfers from local filesystem to plugin, unfortunately I have less free time than I would like to have, so development goes slower than expected.
cubas
error
Post by cubas »
Plugin dont work :-( I add plugin in "Plugin Manager" and after I see following errors :-(
error1
error1
error2
error2
rajce.net | místo pro vaše fotografie
manison
Re: error
Post by manison »
cubas wrote:Plugin dont work :-( I add plugin in "Plugin Manager" and after I see following errors :-(
This error is reported when proxy fails to initialize the Total Commander plugin. Are you sure you have any TC plugin copied into the same directory where the proxy (tcfs.spl) is located? Does it have the WFX extension? If so, what TC plugin is it?
cubas
Post by cubas »
thanks for help, its working!!! :-)
sergo
hi
Post by sergo »
copy and e.t.c. operation not working ):
screen
screen
Re: hi
sergo wrote:copy and e.t.c. operation not working ):
Is this a bug report or a feature request, 'cause you know, I can't tell. At least, you could tell us, what TC FS plugin you want to use.
sergo
Post by sergo »
copy and etc operation work is use plugin disk panel,
if use standart disk panel and copy file to plugin panel, then show this message ):
sergo
Post by sergo »
this is not bug report.
use NetworkAlt, NeroPanel, CD/DVD Burner - all not work soceful
(my bad english (: )
gnozal
Post by gnozal »
sergo wrote:this is not bug report.
Total Commander CD/DVD Burning Plugin only works with TotalCMD, not with EFCommander, SpeedCommander, ...
Read the license.
"This software is a plugin for the file manager Total Commander by Christian Ghisler and may only be used within that file manager. Its functions may not be called from any other application, and it may not be incorporated in any other software package. Use in any other file manager that supports the Total Commander plugin interface is only allowed with express permission of the developer."
