Vista: Copy/Move to Network yields error/ Pasting not
GuidoR13
Post by GuidoR13 »
Hello,
using Salamander 2.5 under Vista:
I get an Error (53) (Network path not found) when copying with F5 to some network path, using Ctrl-C in source and Ctrl-V in target works...
Any ideas, that's ANNOYING.
Guido
Is it UNC (\\server\share) path or mapped network drive?
Could you reproduce this problem with other network servers (for example map your own shared directory)?
GuidoR13
Post by GuidoR13 »
An UNC-Drive and it seems that this behaviour ONLY occurs, when I address a windows system directory, e.g. \\remotepc\Windows\System32 where local and remote system running Windows Vista.
Unfortunately not reproducable, normally copying with F5 works, but sometimes not (then Ctrl-C Tab Ctrl-V works).
