Hello,
I want to be able to assign a key shortcut (e.g. CTRL-D) to a specific user menu entry, e.g. winmerge, like it is possible to do this for plugins.
The hotkey F9 only displays the whole user menu.
Thanx in advance,
MuellerD
Key shortcut for user menu _entry_
It is possible to define User Menu hot key using '&' character. Insert ampersand character before a choosed letter. For example: CVS &Update. Then use this hot key: F9, u.
More information about User Menu: http://www.altap.cz/salam_en/help/salam ... _usrmn.htm
