What happened to ...
Guest
Post by Guest »
Petr Solin?
Best regards,
Guest Nr.XYZ
I'm still alive, don't worry. 8) What should happen to me?
omega
Post by omega »
i guess someone misses you Petr :D
Guest
Post by Guest »
Just wanted to say thanks for inventing the original Servant Salamander, I am using it for more than 10 years now ;)
Best regards and good luck to you all,
Guest Nr.XYZ
