It happens that Altap Salamander (only with 2.5 final, i haven't noticed this behavior in any RC) exits without any message. It seems that the crash occurs when the panel is refreshed, p.e. when a download is running in the active panel.
(HP Evo D330M, Win XP)
						Program exit without any error message
Do you use Tortoise SVN (CVS)? Or other software using icon overlays (for example PixVue)?
				Guest
This problem is PROBABLY related to TortoiseSVN.
Icon overlay shell extensions are called for every displayed file and directory (not only for repository tree).
Please look at
http://forum.altap.cz/viewtopic.php?t=1968
http://article.gmane.org/gmane.comp.ver ... evel/28883
What version of TortoiseSVN are you using? Latest 1.4.3? If no, could you please upgrade to this version and let us know?
Please look at
				Guest
				Guest
Problem solution: http://forum.altap.cz/viewtopic.php?p=9882#9882
