At work, we have a network share that I do not have access to directly; however, I have access to a subdirectory (example: \\servername\share -> no access, but \\servername\share\subdir -> access OK).
With Windows Explorer, this works if I enter the complete path \\servername\share\subdir in the location bar or click on a link in an email.
However, when I use Shift+F7 in Altap Salamander RC3 and enter \\servername\share\subdir, I get an error message "5 Network error: Zugriff verweigert" (permission denied) for path \\servername\share.
Is it possible to make Altap Salamander change directly to a subdirectory of a network share, without changing to the top-level share first? Either by default or with a checkbox in the Shift+F7 dialog, like the "send path directly to plugin" checkbox?
Change directory to a subdirectory of a network share
This particular machine is a Windows server (probably NT or 2000).
By the way, in case I was misunderstood, I don't need to map a drive letter to a subdirectory -- I'd like to use the UNC path to change the directory directly. It's OK if the top says \\servername\share\subdir\subsubdir instead of M:\subsubdir.
