File permissions dialog
Ctrl+P or Files->Security->Permissions in the menu brings up the file properties dialog instead of the file permissions dialog.
Re: RC3: Can't get the file permissions dialog
Yep - same bug hereth. wrote:Ctrl+P or Files->Security->Permissions in the menu brings up the file properties dialog instead of the file permissions dialog.
Kind regards, KNUT
Confirmed!th. wrote:Ctrl+P or Files->Security->Permissions in the menu brings up the file properties dialog instead of the file permissions dialog.
Floppy
The obsolete (NT4) Permissions dialog box was removed in 2.5 RC3, it doesn't work well on Windows 2000, XP, and Vista and was out of our control.
Instead the Security page of Properties dialog box is opened (if it is available from Windows Explorer).
To display the Security tab:
(Windows XP Professional)
http://www.microsoft.com/resources/docu ... x?mfr=true
(Windows XP Home)
http://www.lockergnome.com/nexus/window ... e-edition/
(Windows XP Home)
Yes, indeed. Same behavior here!th. wrote:But here always the first page ("Allgemein" in German version of Windows XP) of the file properties dialog is displayed so I have to change manually to the security page.
... is called "Freigabe" in the german version.Security page of Properties dialog box
Kind regards, KNUT
I can see "Sicherheit" but it starts always with "Allgemein" using RC3.Jan Rysavy wrote:Can you see the Security page in the Properties dialog box?Lio_Major wrote:When will this be fixed?
RC2 worked and had its own Window to set File-Security, kinda liked it.
Was easy to handle, much better than Windows way to set it.a
I think there should be the possebility via Option to changeJan Rysavy wrote:There are still some NT4 users?th. wrote:I think that the permissions dialog should be re-added at least if AS is run under NT4 (in RC3 the function is grayed out).
Strg-P Style how to show Security-Dialog. Windows / Servant Salamander wise.
(Maybe an System auto-detection will do fine.)
