Will the FTP plugin be able to estabilish a secure connection in the future? SFTP or SSL/TLS, etc.
thanks!
Adaz
Secure FTP
Re: Secure FTP
SFTP is implemented, yet.adaz wrote: Will the FTP plugin be able to estabilish a secure connection in the future? SFTP or SSL/TLS, etc.
Version 2.5 full.
EDIT: As stand-alone plugin, not part of ftp plugin. Expect. Not using for a long time - have standard installed now.
Re: Secure FTP
Thanks, but I have a Serv-U ftp server which supports SSL/TLS encryption, but WinSCP plugin cannot connect to it. Did I something wrong, or that won't work?Datalog wrote: SFTP is implemented, yet.
thanks
Re: Secure FTP
Maybe we should clarify what (s)FTP(s) is.
SFTP is Secure FTP, known as SSH FTP. This is already done via SCP/SFTP plugin.
FTPs is FTP thru SSL/TLS. This isn't available now.
Jiri {x2} Cincura
Re: Secure FTP
Thank you very much! Then waiting for the SSL/TLS support.
