This format is used by hemera and their clipart collections. From the link below: Any HPI file consists of a fixed 32-byte header which resembles the header used in PNG (Portable Network Graphics) files. Following this header, the color image information is presented in JPEG format.
I have created in the past, converters (using PHP) but would prefer to keep the HPI files intact in their normal format. If this format could be added to the thumbnail viewer for panels and the pictview plugin, that would be awesome.
Here is the link:
http://www.halley.cc/ed/linux/interop/hemera.html
FYI xnView Professional supports this format, as do other products I am sure. Thanks!
PS: If you want the source for the converter I rolled (it's PHP format) I can provide it.
HPI Image Format Support for Panels/Pictview
Re: HPI Image Format Support for Panels/Pictview
Could you please send me some sample images?grymmjack wrote:PS: If you want the source for the converter I rolled (it's PHP format) I can provide it.
Either to support[at]pictview_doc_com or (if large) via http://www.yousendit.com
Thanks
Sent email. Thanks Jan.Jan Patera wrote:Could you please send me some sample images?grymmjack wrote:PS: If you want the source for the converter I rolled (it's PHP format) I can provide it.
Thanks
Implemented for Salamander 2.5 Beta 11grymmjack wrote:This format is used by Hemera and their clipart collections. From the link below: Any HPI file consists of a fixed 32-byte header which resembles the header used in PNG (Portable Network Graphics) files. Following this header, the color image information is presented in JPEG format.
grymmjack posted at Thu Jan 19, 2006 3:11 am.
6 minutes for the implementation!!Jan Patera posted at Thu Jan 19, 2006 3:17 pm.
Jan, you're a wizard
Kind regards, KNUT
Awesome. Thanks so much. I always knew you guys were code-gurus and this not only confirms my theory but proves unequivocally that you dont use any non-original code or libraries common in other devteams (besides the actual file format specifications which you must use).Jan Patera wrote:Implemented for Salamander 2.5 Beta 11grymmjack wrote:This format is used by Hemera and their clipart collections. From the link below: Any HPI file consists of a fixed 32-byte header which resembles the header used in PNG (Portable Network Graphics) files. Following this header, the color image information is presented in JPEG format.
Jan, you also code eroica yes? I would like the full features in my SS for that system, is it possible that the plugin could be registered for SS? I would like to pay for your support/time, and I use eroica features often.
