Downlad
Re: Downlad
Just noting...
Salamander 5.0.5, Date Sort
Sorts files by date,
but does NOT sort directories by date.
(I didn't look through the options, so maybe there is a setting ?, but if not...)
Re: Downlad
Working for me
Re: Downlad
Máte skúsenosti so stabilitou týchto verzií?
v5.0.6
Re: Downlad
skusam prvy krat, okrem tohoto som zatial nenarazil na iny problem
Gtein
Re: Downlad
Post by Gtein »
Proč tam není český jazyk?
Re: Downlad
Gtein wrote: 18 Feb 2026, 20:28 Proč tam není český jazyk?
Nenašiel sa nikto kto by ju urobil. :wink:
Gtein
Re: Downlad
Post by Gtein »
AD7 wrote: 19 Feb 2026, 16:26
Jak není když tam je i s dalšími jazyky.
vilo
Re: Downlad
Post by vilo »
Tie preklady tam neboli uplne kompletne, uz som sa na to chystal davnejsie, ze im to updatnem, nachystal som to az teraz:
https://github.com/OpenSalamander/salamander/pull/354
Asi chvilu potrva, kym mi to maintaineri mergnu. Kto chcete vyskusat, potahajte si moju branchu lang-modules, alebo branchu github-ci, tu sa mi to uz cele pekne zbuildi...
Re: Downlad
v5.0.9
https://github.com/0xeb/salamander/releases/tag/v5.0.9
...podpora pluginov z verzie 4.0, dobre čítam? :D
Re: Downlad
Open Salamander 5 je teraz Sally v1.0.1:
https://github.com/0xeb/sally/releases/latest
Re: Downlad
Tesim sa, ze sa niekto ujal dalsieho vyvoja, ale priznam sa, ze tato zmena mena ma velmi nepotesila.
Neviem ako ostatni, osobne preferujem formu "Open Salamander - <prilvlastok".
i.e. "Open Salamander by Sally", "Open Salamander - RedDwarf", "Open Salamander [Zen Edition]"
dpokluda
Re: Downlad
Post by dpokluda »
Souhlasim se SelfMan a taky bych preferoval Open Salamander nez Sally!
Mimochodem, zkusil jsem si stahnout ZIP x64 verzi a Windows Defender reportuje prezenci "Trojan:Win32/Wacatac.H!ml" v "Sally\utils\salmon.exe"! False positive?
Re: Downlad
Working for me
@SelfMan
Thanks.
Has been so many years, decades, since I must have set that setting, I simply forgot.
And not seeing directories sorted as (I) expected was immediately apparent.
[And then lack of time, & a little bit of laziness... heh, it was easier to post here then actually took.]
KRtek&#8482;
Re: Downlad
Post by KRtek&#8482; »
V Open Salamander: Samandarin je dostupná pouze angličtina, překlady ještě nejsou k dispozici. Tehdy se pracovalo na překladu komentářů původního kódu, já zároveň přidával celou tu Tabbed Panels funkcionalitu, která do překladových souborů přidává nové stringy.
Někdo mě kontaktoval mailem, že by rád udělal překlad do němčiny, stejně tak je požadavek na githubu pro překlad do češtiny - počítám s tím. Jakmile se zase dostanu k vývoji a práci na verzi 0.2, mám v plánu udělat trochu větší pořádek v repozitáři, zjednodušit proces orchestrace buildu (protože se vyrábí z několika pracovních branchí, což momentálně komplikuje práci právě překladatelům).
KRtekTM, KRtek™
https://samandarin.net/
Re: Downlad
Díky za dobré správy. :)
