Hi guys,
I figured out that there should be a winSCP Plugin available with which I should be able to synchronize folders in my home network.
But I couldn't find it in my plugins menu.
Even after repairing the Salamander installation (by rerunning the setup) nor by installing the winSCP setup, I'm still not able to find the plugin in Salamander.
Am I doing or did I get something wrong?
Many thanks
M
WinSCP Plugin missing
Re: WinSCP Plugin missing
WinSCP does not have a 64 bit plugin version so it is not available in 64 bit Salamander.
OK. Got it. Thanks for this hint!
Would have been a cool thing, when the creators of the winscp would provide this info on their page as well (https://winscp.net/eng/docs/salamander".
Regards
M
Regards
M
You can use the workaround I came up with: "Replacing WinSCP with sftp plugin on AS x64 4.0" - viewtopic.php?f=4&p=70614#p70614.
Or even better you can try to add WinSCP 64bit yourself
