Can´t copy to shared folder
jaymz1097
Post by jaymz1097 »
Hello,
I´ve installed most recent version and set a shared folder on local network for the client. Everything works fine, however in Salamander I can´t copy into the shared folder any file. The permissions are set to Everyone with full access within the network.
Is there a setting that needs to be adjusted in Salamander?
Thank you
Re: Can´t copy to shared folder
Are you running Salamander as Administrator or in User level mode?
jaymz1097
Post by jaymz1097 »
Yes. There's only one user account that is Admin and UAC level is set to the lowest one - no prompts.
You have to take in account that even in such case it behaves like a different user. If you are not in a domain, you have to create an identical username/password combo on the target machine to be able to get in.
Also, you might add the followin registry key on the target system:
REG ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System /v LocalAccountTokenFilterPolicy /t REG_DWORD /d 0x00000001 /f
More on that: https://learn.microsoft.com/en-us/troub ... estriction
jaymz1097
Post by jaymz1097 »
Thanks, but the shared folder is on that very computer on C:\ drive, so there should not be an issue with the permissions? Copying files in Windows Explorer works just fine.
When you run Salamander as standard user (not admnistrator) how does it behave?
jaymz1097
Post by jaymz1097 »
Only one account is set on that machine, don't want to create more accounts as this is not needed for the user. It looks like some permission issue within Salamander, is it fixable?
Take a Screenshot of the running Salamander and post the top title bar here.
Also, you have to set up the share permissions && file level permissions on the folder.
jaymz1097
Post by jaymz1097 »
The permissions are set fine, as in Explorer I can´t do anything with the files, only Salamander doesn´t work.
Again, what are the NTFS permissions on the shared folder?
jaymz1097
Post by jaymz1097 »
Everyone has full access - local accounts or over LAN.
What happens if you use Shift+F7 and enter \\127.0.0.1\SharedFolderName ?
jaymz1097
Post by jaymz1097 »
Using the direct address opens the shared folder in Salamander fine, but files still cannot be copied. Outcome is the same as navigating through This PC - Network.
Took photos of permissions for this folder.
Image 2023-05-31 at 12.59.23 PM.jpeg (20.28 KiB) Viewed 88574 times
Image 2023-05-31 at 12.59.55 PM.jpeg (33.96 KiB) Viewed 88574 times
Check the access right on the existing subfolders too.
Change the owner of the shared folder to admin if it isn't and then let the access rights propagate to the existing subfolders.
FYI www.selfman.sk
jaymz1097
Post by jaymz1097 »
Chcel som radsej pisat v EN keby to niekto dalej hladal, inak https://vlkotech.sk/)
The folder lies in the root of C:\ and has no files or subfolders inside. It´s completely empty at this point. If I try to copy something in Salamander, I get the blocked cursor thing and nothing really happens. I really feel this is a bug that ca be easily reproduced on a clean install of W10 64bit with latest updates and most recent version of Salamander. The network is set to be discoverable and everything works OK in native Explorer.
Is there a way to fill in a bug?
