In my case I needed several file type associations and their file type definitions e.g.
HKEY_CLASSES_ROOT\.txt HKEY_CLASSES_ROOT\.doc HKEY_CLASSES_ROOT\.rtf HKEY_CLASSES_ROOT\txtfile HKEY_CLASSES_ROOT\rtffile
The simplest and safest method is to use MS Windows tools. There is a CLI based too calledSvA wrote: 11 Jan 2022, 20:09 Does anybody know: Is there a way to export several marked keys or values from the Regstry plugin?
In my case I needed several file type associations and their file type definitions e.g.Or else, does anybody know a free tool capable of doing this, regardless if it is a gui, command line, or configuration file based one? It should produce standard windows .reg files.
reg export
reg export 'HKEY_CLASSES_ROOT\.txt' txt_export.reg
reg export /?
REG EXPORT KeyName FileName [/y] [/reg:32 | /reg:64]
Keyname ROOTKEY[\SubKey] (local machine only).
ROOTKEY [ HKLM | HKCU | HKCR | HKU | HKCC ]
SubKey The full name of a registry key under the selected ROOTKEY.
FileName The name of the disk file to export.
/y Force overwriting the existing file without prompt.
/reg:32 Specifies the key should be accessed using the 32-bit registry view.
/reg:64 Specifies the key should be accessed using the 64-bit registry view.
Examples:
REG EXPORT HKLM\Software\MyCo\MyApp AppBkUp.reg
Exports all subkeys and values of the key MyApp to the file AppBkUp.reg
As sorry, I thought that would be easy for you. You just need to run the script (it does not matter which scripting you use - PowerShell, batch, javascript, vbscript, etc.) in a loop, export the registry into some temporary file names and then merge those files into one file. Everything would be done automagically by the script.SvA wrote: 12 Jan 2022, 16:43 Thanks for your reply.
I know about reg.exe. It has the same restriction as Salamander and as Regedit. You can export one key only into a file. You cannot even append more data to a pre-existing file. Rather they all overwrite the file with the new data.
If you need a collection of keys, you will have to merge the files created in several exports in the editor. I am looking for a more direct, less manual way of exporting several keys in one go, or even in multiple commands, but without manual merging.
All tools known to me take one parameter to specify one key and export this key, if it is a data-key, and all contained keys, if the specified key is a folder.
You mentioned PowerShell. This might be a possible solution. I will have to investigate ...
Yes, the first reply by Ansgar Wiechers is the way I would do it. He even nicely got rid of the first line 'Windows Registry Editor Version 5.00' and has it only once the merged file.SelfMan wrote: 13 Jan 2022, 02:11 https://stackoverflow.com/questions/280 ... e-reg-file
Working with Registry Keys using PowerShell
https://docs.microsoft.com/en-us/powers ... rshell-7.2
