Pictview and Eroiica viewer problem
Jim V
How exactly do Pictview and Eroiica viewers work? When I select, for example, a jpg file in the panel view and go to Pulgins, pictview menu, there is no option to show the selected jpg file. It just shows a grayed out "view bitmap from clipboard", screen capture, etc. Am I missing something? Please help.
Re: Pictview and Eroiica viewer problem
You right, in the menu is missing option view.Jim V wrote:How exactly do Pictview and Eroiica viewers work? When I select, for example, a jpg file in the panel view and go to Pulgins, pictview menu, there is no option to show the selected jpg file. It just shows a grayed out "view bitmap from clipboard", screen capture, etc. Am I missing something? Please help.
Anyway, for viewing files is primary designed key F3, in case of some extra files you can view the source code by pressing ALT+F3
