JSON Viewer Plugin
Re: JSON Viewer Plugin
mdruiter wrote: 18 Feb 2021, 10:54 Looks like the plugin does not work for Altap Salamander 4.0. I get this error when I try to add the plugin:
Unable to load plugin (<path>\plugins\jsonviewer\jsonviewer.spl) or some of its components.
Error: (1400) Invalid window handle.
See plugin details in menu Plugins / Plugins Manager.
Is there an updated version available?
While it would be great to have the plugin with the source, we don't have it. The original author visited the forum on Oct, 2020 so we don't know if he is gonna visit us again.
I'm using JSONedit instead. Give it a try. The only thing I don't like is that it does not support overall black theme (only for the text tab only).
It gives you tree tabs text/tree/list where you can have different views of the JSON. It is really fast even on larger JSON files.
