salextx64.dll
mesajflaviu
salextx64.dll
Post by mesajflaviu » 05 Feb 2020, 13:02
I have on my HDD a folder as308sdk, to test your software. And when I have tried to delete it, I cannot delete two files: salextx64.dll and salextx86.dll. I have seek it on registry, and I deleted from there, but I still cannot delete these files from HDD .. .why ? Can you help me ?
Re: salextx64.dll
Post by SvA » 05 Feb 2020, 19:56
these are shell extensions.
Try to unregister them from an elevated command prompt using
regsvr32 /u <file.dll>
(Replace <file.dll> with absolute or relative path to the files in use by the system.)
Then, after a reboot, you should be able to delete them.
mesajflaviu
Re: salextx64.dll
Post by mesajflaviu » 10 Feb 2020, 09:23
Yes, it worked. Thank you.
