Portable Altap Salamander v2
crystalidea
Post by crystalidea »
No bat files, works fine with multiple instances of AS. Config file is stored in AS directory as a single .dat file
How to use:
AS = Altap Salamander
XML = salamand_portable.xml
1. Download and unpack the attached file. It's recommended to place XML into AS folder. If you placed XML to some other folder, edit 'exePath' in XML to match the full path of 'salamand.exe' on your machine. 'RunAppPortable.exe' and other files can be also put into AS folder unless you plan to run some other apps in portable mode using RunAppPortable.
2. Create a shortcut to 'RunAppPortable.exe' and specify XML path as parameter (see attached picture). You can also change icon of the shortcut to the one used by 'salamand.exe'.
3. Enjoy. Feedback is welcome here
Features:
- Portable version works without conflicts with normal version
- "(Portable)" is appended to window title
- Tested to work on different machines when AS is located in Dropbox
- Works on network drives
- Works well with multiple AS instances
- Source code to be available soon
Known limitations of RunAppPortable:
- Requires process elevation (administrator rights)
- No 64-bit executables support (soon)
- Not much tested with other apps, but it should work
To be updated.
salamand_portable.zip
(242.84 KiB) Downloaded 4135 times
crystalidea
Re: Portable Altap Salamander v2
Updated to version 0.9.1: using temporary folder for data file path to avoid conflicts with cloud synchronization services (e.g. Dropbox). Data file is actually modified only after app exit
orhor
Post by orhor »
please, provide a way to import Salamander config file. Thank you.
crystalidea
This option exists (when RunAppPortable is run the first time)
Melloware
Post by Melloware »
Can you make a portable 4.0 now that it is Freeware?
Melloware Inc.
http://www.melloware.com
(Note that "the archive" aka salamand_portable.zip has been updated over time. Latest as of 7-19-2018.
Don't know if actual changes or only something like the digital signature?)
crystalidea
Melloware wrote: 09 Jul 2019, 14:44 Can you make a portable 4.0 now that it is Freeware?
It works fine with 4.0
crystalidea
therube wrote: 09 Jul 2019, 18:47 (Note that "the archive" aka salamand_portable.zip has been updated over time. Latest as of 7-19-2018.
Some minor stuff, can't remember exactly, sorry
crystalidea
I'll open source it a little bit later so anyone can improve the plugin.
Tigerente
Post by Tigerente »
crystalidea wrote: 11 Jul 2019, 20:12 I'll open source it a little bit later so anyone can improve the plugin.
Thank you very much for your effort! :)
Is there any update on the 64 bit matter?
Unfortunately, I could not find your souce code. Have you ever thought about releasing a PortableApps version? This would make Altap Salamander known to a wider audience.
