Edit the Software
Newplay123
Edit the Software
Post by Newplay123 »
Hello,
I have a question about the “Altap Salamander” program.
Is there a way to edit the software so that users can no longer click on menu items like "Customize Plugins" or "Configuration" ?
I hope you can help me.
Re: Edit the Software
It is not possible.
Newplay123
Jan Rysavy wrote: 08 Jul 2019, 12:08 It is not possible.
Is there a way to do this via "regedit" ?
No, it isn't. Please tell us more... why do you need such option?
Newplay123
Jan Rysavy wrote: 08 Jul 2019, 13:49 No, it isn't. Please tell us more... why do you need such option?
I work in a company with 5 employees.
They should not be able to change any settings in the program.
Unfortunately Salamander is not prepared for this usage scenario.
Newplay123 wrote: 08 Jul 2019, 13:52
I think your only option is to save the settings and overwrite the registry every time AS is started. You will have the AS always the same.
1) You can try setting Salamander's registry keys as write protected for users using ACL so the users cannot save the changed configuration. Then there will be no need for reapplying your configuration configuration.
2) You can also uncheck the "Save configuration on exit" checkbox so the Salamander
(manually using the "Options > Save configuration" from the main menu will still save the configuration)
Slanec
Post by Slanec »
Newplay123 wrote: 08 Jul 2019, 13:52 I work in a company with 5 employees.
As an employee, please do not do this. If your employees are advanced enough to meddle with something in the Configuration menu, they should be allowed to do so. IT beginners will not randomly go there, change things randomly and click Save.
bernard56
Post by bernard56 »
Hi, I have a question about the “Altap Salamander” program. Is there a way to edit the software so that users can no longer click on menu items like "Customize Plugins"? More details and possible solutions: here
StevaHong
Post by StevaHong »
Good point. I’ve noticed some archive formats behave differently depending on how they were originally packed too. Sometimes just recreating the archive with a newer compression method fixes a lot of these odd extraction issues.
