- to adapt to the DPIs varying between different monitors and
 - to switch between overview (very small font size) and details (readable, bigger font size) for a file.
Allow zooming via CTRL+Mousewheel in viewer, file comparator etc.
Allow zooming via CTRL+Mousewheel in viewer, file comparator etc. instead of having to go to configuration and set a different font size. With that feature, it becomes fast and easy
							Using Salamander since v 1.52
						Re: Allow zooming via CTRL+Mousewheel in viewer, file comparator etc.
Agreed.  This would be really helpful.
The code is already there for PictView so it should not be that difficult.
