Unicode Support
KNUT
Re: Unicode Support
Post by KNUT »
omega wrote:Any update Jan?
Any update Jan?
Kind regards, KNUT
crystalidea
Re: Unicode Support
Post by crystalidea »
Yes, please, any update. Is the project alive actually? It's been a while (>5 years) since you promised Unicode.
omega
Re: Unicode Support
Post by omega »
crystalidea wrote:Yes, please, any update. Is the project alive actually? It's been a while (>5 years) since you promised Unicode.
Holiday season, must be out of office :D
Re: Unicode Support
For critical case of Unicode need I use Notepad++ and for complicated rename of unicode filenames I started use XYplorer 18 (https://www.xyplorer.com/product.php). It works very good. :D
tosi
Re: Unicode Support
Post by tosi »
+1
thuety
Re: Unicode Support
Post by thuety »
This would make the product complete!
camper
Re: Unicode Support
Post by camper »
My most complain about AS not supporting unicode is that the Viewer does not support UTF-8.
vygi
Re: Unicode Support
Post by vygi »
+1
BTW, I badly need the working WinSCP plugin. It does not work with the new Linux servers anymore as soon as they use OpenSSH newer that 7.1
I've asked for workarounds in the the WinSCP support forum and got following answer:
Yes, the plugin needs to update.
But unfortunately, WinSCP was meanwhile updated to Unicode, what makes it incompatible with Altap Salamander API. I'm waiting for them to release Unicode version of Salamander.
thuety
Re: Unicode Support
Post by thuety »
any update?
omega
Re: Unicode Support
Post by omega »
thuety wrote: 11 Dec 2017, 10:06any update?
viewtopic.php?f=4&t=31870&start=30#p61609
nieboras.jan
Re: Unicode Support
Post by nieboras.jan »
Hi, just saw this thread and obviously it is few years already that Salamander does not support unicode file names. I can still see just ???? question marks and have to open explorer for simple operations like opening/copying the files.
Any updates on this feature?
Thank you
Delphi-Coder
Re: Unicode Support
Post by Delphi-Coder »
This is excellent software and the biggest weakness is lack of unicode support. I'm still waiting impatiently to see Unicode support. It should not be difficult job for developers as there is unicode equivalent for any ansi api.
ticris
Re: Unicode Support
Post by ticris »
I second that. I have big problems with the Romanian special characters in filenames.
Delphi-Coder
Unicode Support
It would be great if developers add Unicode support to this software. Not sure but I think it couldn't take more than a week or two.
Any plan for adding this feature?
Re: Unicode Support
There wont be any Unicode support anytime soon. Please search the forum for unicode.
