Salamander 3.07 x86 - Check for new versions
thomas
Post by thomas »
Hello,
there is a problem with the update checker.
I got follow message:
Connecting failed: An error occured in the secure channel support
Re: Salamander 3.07 x86 - Check for new versions
What Windows version are you using?
thomas
Post by thomas »
Hello Jan,
Windows XP SP3 x86 :wink:
Best regards,
Thomas
I can reproduce this problem, thank you for reporting it.
thomas
Post by thomas »
Windows 10 x64
Salamander 3.07 x64
Update checker doesn't find new version 3.08!
Info:
No new modules are available now.
Older or same installed modules:
Altap Salamander 3.07
We will publish AS 3.08 information for Check Version plugin during next week.
