Hello,
there is a problem with the update checker.
I got follow message:
Connecting failed: An error occured in the secure channel support
Salamander 3.07 x86 - Check for new versions
Re: Salamander 3.07 x86 - Check for new versions
What Windows version are you using?
Hello Jan,
Windows XP SP3 x86
Best regards,
Thomas
Windows XP SP3 x86
Best regards,
Thomas
I can reproduce this problem, thank you for reporting it.
Windows 10 x64
Salamander 3.07 x64
Update checker doesn't find new version 3.08!
Info:
No new modules are available now.
Older or same installed modules:
Altap Salamander 3.07
Salamander 3.07 x64
Info:
We will publish AS 3.08 information for Check Version plugin during next week.
