Hello guys,
is there a way to decrypt a File with known password and know encrypt config, encrypted by the salamander plugin, outside Salamander?
I only know that the Salamander plugin is using a Crypto++ 4.1 library.
Did someone know a program for that?
en-/decrypt Files outside Salamander
Re: en-/decrypt Files outside Salamander
Unfortunately never implemented external command line encrypt/decrypt support.
Hey Jan,
the question is, is there any othere program on the market which is able to encrypt such a file, if the password is known.
I have sent someone a decryted File and he wants to encrypt it without using Salamander.
/Bernd
/Bernd
No, such software doesn't exist.
One idea: you can pack files using 7-Zip plugin (make password protected archive).
Such archive could be extracted using standalone 7-Zip application.
