This is my issue:
Since an upgrade to Windows 10 yesterday I do not get the Company Network drives when I am on VPN Connection.
The Windows own Explorer gets everything, but Salamander does not....
any clue what I could do or check?
Please help.
thank you very much and best regards
max
my company network drives no longer show (upgraded to Windows 10)
Re: my company network drives no longer show (upgraded to Windows 10)
Do you run Altap Salamander as Administrator? See main window title, there would be (Administrator) text.
ok, now I get my drives.... thank you!
Still, I am curious, because I originally chose to execute as admin because in an earlier Version of WIN I had the exact same issue with network drives but running as Administrator it stopped, now it is exactly the other way round----
Can you explain why that is?
You can find an explanation for why this happens at https://support.microsoft.com/en-us/kb/3035277.
The remedy given there might, or might not work in your case, depending on how your VPN software interacts with your system.
Thank you very much. Will confront our IT Department, in fact VPN Client changed to a newer one, maybe Settings are not in favour of running Altap in admin role...
