Tipperton
Posts: 5 Joined: 10 Dec 2005, 16:42
Post
by Tipperton » 01 Aug 2006, 02:24
When I first started using Salamander, zipping files always started with the other pane as the default location to create the zip file in.
Now I've noticed that the default has changed to the current pane.
I've looked all over and can't find a specific setting to return it to the original default of the other pane.
Anyone know where this option is or how to change it back to origial setting?
Thanks!
WillM
Posts: 20 Joined: 09 Dec 2005, 19:45
Post
by WillM » 01 Aug 2006, 07:15
Options - Configuration - Archivers should hold the option you are looking for.
Will
Tipperton
Post
by Tipperton » 01 Aug 2006, 13:56
Thank you!
It was there! No wonder I couldn't find it, I was expecting to find it in the confuration for the plug-in itself....
Posts: 488 Joined: 29 Mar 2006, 02:41
Post
by SvA » 01 Aug 2006, 17:05
This setting applies to all archivers, not just the ZIP plugin. Therefore it is in the general archiver configuration setting
