I want to replace the interal PictView Plugin through the Windows Photo Viewer. Therefore I have changed the configuration. From within the file viewer I have done the following change (see hardcopy). The full command is
rundll32.exe "%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll", ImageView_Fullscreen
Nothing happens, when I press F3 on a JPG.
What am I doing wrong? Using cmdline this is working fine.
Thanks and Regards,
Torsten
Replace PictView through Windows Photo Viewer
- 2016-02-28 15_11_53-Konfiguration.png (30.89 KiB) Viewed 15646 times
Re: Replace PictView through Windows Photo Viewer
try FullName instead of Name. Use the following syntax:
%SystemRoot%\System32\rundll32.exe "%ProgramFiles%\Windows Photo Viewer\PhotoViewer.dll",ImageView_Fullscreen <full path to the image without quotes>
you have 2 main error in the configuration:
1) there should be no space character between , and ImageView_Fullscreen - ,ImageView_Fullscreen
2) the "$(Name)" should be without quotes and FullName - $(FullName)
I've tested the line above and its working.
Hi, I dot no get it running with this syntax either. Please see attached hardcopy with the error message. "System cannot find the file"....
Regards,
Torsten
Regards,
Torsten
- 2016-02-29 20_35_18-Fehler.png (6.92 KiB) Viewed 15602 times
Ok, it seems that there is a problem expandisk system variables...%blahblah% so use:
command: C:\Windows\System32\rundll32.exe
argument: "C:\Program files\Windows Photo Viewer\PhotoViewer.dll",ImageView_Fullscreen $(FullName)
Initial directory: $(FullPath)
This is valid for a 32 bit OS. For a 64 bit OS you have to adjust the paths accordingly.
I've tested this configuration and its working.
Yes you are right. No it is working.
Thanks and Regards,
Torsten
Thanks and Regards,
Torsten
