Hello,
It seems that in Windows 10 Salamander doesn't save/export also the sftp details it saves only the ftp details,when I import them back it's empty .. it happened to me a lot of times under different Windows installations. Any solution !?
Also for sftp , is there a way to make the keep alive connection by default for all the sftp profiles ?!
Thanks
Altap Salamander 3.06 x86
Windows 10pro x64
Not saving sftp details on reg export in Windows 10
Re: Not saving sftp details on reg export in Windows 10
Hello,
Thank you for your answer, I managed to save the sftp profiles.
I need a solution to activate by default the "keep alive" for all the profiles in there .. can this be done ?!
Thank you !
Thank you !
Martin Prikryl
To change the defaults, go to Connection tab, enable Keepalives, go back to Stored sessions tab and use Set defaults button.Socoliuc wrote:I need a solution to activate by default the "keep alive" for all the profiles in there .. can this be done ?!
Though this will change defaults for new stored sites only.
If you want to change existing stored sites, you cannot do this with Altap Salamander WinSCP plugin.
But as it shares sites with WinSCP application, you can use WinSCP /batchsettings command-line switch to enable Keepalives for all existing sites:
winscp.exe /batchsettings * PingType=1
See http://winscp.net/eng/docs/commandline#batchsettings
Martin Prikryl
https://winscp.net/
https://winscp.net/
