I'd like to have an additional column that indicates to me if a file or folder is availalble offline. "Make available Offline"
It can also work if it only becomes an additional Attribute letter like you have for Read-only, System, Hidden, etc
I guess the solution depends on how the Server reports that it is available offline.
Offline Available column or Attribute
2MrAsker:
The context menu reveals if a file/folder is available offline. If yes, the entry "Make available offline" is checked.
But I would prefer the Explorer style with a slightly different icon for the folder. This would allow to check a folder structure much more quickly.
I know that icon overlays are also on the roadmap, but the question is if that would include the available offline indicator.
