An NT Event viewer plugin to allow you to view NT Event logs might be handy in some situations. It could behave mostly like the registry plugin does now.
I often need to check the event logs for any errors or warnings and i hate it that i have to switch from SS
Hi eblis,
Altap have gave you an 'user menu' for e.g. add an link to such tools.
Try:
Command: eventVwr.msc
Arguments:
Initial Dir: $(FullPath)
[ ] execute througt shell
[ ] open shell window
[ ] close shell window
[x] show item
BTW @Altap:
you should allow use to emtpy the "Initial Dir" field for such issues ? Or ?
$(FullPath) doesn't hurts here, but it's unnecessary.
Try:
Arguments:
[x] show item
BTW @Altap:
AbteriX
