Salamander in conjuction with Actual window minimizer
Smr7omeC
Post by Smr7omeC »
Hi Altap,
Well I tried this application and Salamnader leaves some message window open. For example, if I connect with winscp plugin it leaves the window with the successful connect open and it can't be closed. If disconnect the window changes to Listing path "path", press the ESC key to cancel... and it can't be closed.
I wonder if it is Salamander problem or perhpas the minimazier is changing the API of the windows somehow.
see ya
p.s. here is the homepage if you want to test it http://www.actualtools.com/windowminimizer/
We don't know about this problem.
Could you please try to turn off Minimizer and test Servant Salamander 2.5?
Smr7omeC
Post by Smr7omeC »
cheers,
I tested it and without it, it runs just fine. However, the problem lies in the following. As you can see at the picture http://www.actualtools.com/images/awm_s ... _large.gif there is a fourth button at the top-right of the window which causes the problem
Please contact http://www.actualtools.com/ and report them this problem. Include step by step instructions how to reproduce it.
