I really don't see the need for two features that, more or less, can be used to do the same thing. Copy name as text is a stripped down version of File list feature that only copies one selected file wich makes it not all that useful.
I understand the need to quickly copy a filename (with or without path) to the clipboard - hell, I use it all the time - but it would be much nicer if it'd copy all selected files to clipboard as well.
Or simply do away with it as it's misleading Total Commander switchers.
