McLion
Posts: 78 Joined: 26 Apr 2006, 17:54
Post
by McLion » 09 May 2006, 14:55
Is it correct that Salamander can not be used with CD-RW's?
It says '0' Free Space and can not create a new folder nor copy files to it as it can be done from explorer.
If I am not doing something wrong and this really is not possible this would be one my 'Feature Request' list.
Franz
using:
Win XP pro SP2, german
Salamander 2.5 RC1
Posts: 5231 Joined: 08 Dec 2005, 06:34
Post
by Jan Rysavy » 09 May 2006, 15:16
Do you use some special software for "packet writing"?
Otherwise, do you mean the Windows XP burning capability?
McLion
Post
by McLion » 09 May 2006, 19:30
I don't have any additional software installed. I am using native XP burning capability. This applies to CD-R's as well.
Post
by Jan Rysavy » 10 May 2006, 01:08
The native Windows XP CD-R(W) burning is not supported by SS 2.5 RC1.
We could look at this feature in Servant Salamander 3.0, if there will be demand for it.
johnd126
Posts: 35 Joined: 19 Feb 2006, 01:05
Post
by johnd126 » 10 Jul 2006, 22:47
I too would love to see this feature in SS.
povesteam
Posts: 2 Joined: 01 Nov 2006, 10:52
Post
by povesteam » 01 Nov 2006, 11:07
i want it too... even if the cd is cd-r or cd-rw, or maybe dvd+-... etc... could it be burned by salamander?
