Every time I delete a file(s) and then need to restore them from the recycle bin, I need to open a new window (recycle bin), then restore - especially troublesome when the're many files - manually selecting them in the recycle bin window - this is really a trouble.
Are you planning to make a Redo feature (Ctrl+Z, etc) for such tasks?
I suppose many people want this feature to exist.
						Feature: restore the deleted file (Undo)
- crystalidea
Re: Feature: restore the deleted file
You mean "Undo", I guess.XPiS wrote:Are you planning to make a Redo feature (Ctrl+Z, etc) for such tasks?
+1
Of course, it would be great to be able to set the Undo history size, and that Undo works on renames, too...
ctrl-z
Actually this makes sense.. With this feature in SS I would actually see a reason to have a recyclebin.. I usually never use the recyclebin feature..
I might even say it would be nice if SS had a recyclebin option all by it self. One that could be configured to automatically be active on configurable file types. The only types I feel I need a recycle bin for is stuff like .doc .txt and similar. So I would believe there would be a general appreciation for some sort of SS-Trashcan feature.
