1. My Administrator set up an encrypted directory on my local harddrive. Everything that is copied/moved into it is encrypted automatically. Filenames are displayed in green.
2. However, if I move files via "F6" in SS into that directory, the encryption attribute in "Properties-Advanced" is not set.
3. If I move a file from Windows Explorer (also Desktop) by dragging it into the SS window (displaying the encrypted directory), the encryption attribute is set.
4. If I copy such file via "F5" into the encrypted directory, the encryption attribute is set.
Hope that helps. I have little experience with encryption, so it might be that it's some kind of a Windows bug (I use XP SP2 German version).
Best,
Stefan
