When I mark directories and press ALT-F7 (FIND-Dialog), I would suggest to have the marked directories (or files) be filled in the field "Look In" as a semicolon-separated list.
Actually, I have to write this list manually, e.g. "C:\Dir1;C:\dir2;C:\dir3".
ALT-F7: Fill marked directories in FIND-Dialog
Re: ALT-F7: Fill marked directories in FIND-Dialog
Yep - "must have"STOECK wrote:When I mark directories and press ALT-F7 (FIND-Dialog), I would suggest to have the marked directories (or files) be filled in the field "Look In" as a semicolon-separated list.
Kind regards, KNUT
Yes, I want it too
Jan told me for months (by mail in that old times) that this is on his ToDo list.STOECK wrote:... I would suggest to have the marked directories (or files) be filled in the field "Look In" as a semicolon-separated list.
I deeply hope to see this behaviour soon too
AbteriX
