choice of icons?
choice of icons?
My staff and I are really thrown by the new Icon for Servant Salamander.
We have been users for years, and are really used to the old one;
so much so that we now keep regularly searching for it on the task
bar and missing the new icon, (which now closely resembles the
Firefox icon in color and shape.) Would it be possible to have the use
of the old icon be an option we could select, so we don't keep losing
SS on the task bar?
Regards,
/Will Sadkin
Parlance Corporation
SS on the task bar?
Regards,
/Will Sadkin
Hello Will,
Could you please use the new Servant Salamander icon for at least two weeks?
In ALTAP it took us two weeks (and we are very conservative) to teach recognize it.
Do you have problem to associate the new icon with Servant Salamander?
Or there is a visual conflict with some similar looking icon? (Outlook, Firefox,...)
There is easy way how to return to the old icon (for example using Resource Hacker, freeware resource editor).
The old icons are available in SALAMAND.EXE.
I use it for two weeks now 27.01. - 10.02.Jan Rysavy wrote:Could you please use the new Servant Salamander icon for at least two weeks?
Absolutely, look here:Jan Rysavy wrote:Do you have problem to associate the new icon with Servant Salamander?
What about letting the user choose one of the different available colors of the new icon from a list? I would prefer the blue one.Jan Rysavy wrote:There is easy way how to return to the old icon (for example using Resource Hacker, freeware resource editor).
As mentioned here: Nice new Icon but clearly near to the MS-Outlook iconJan Rysavy wrote:Or there is a visual conflict with some similar looking icon? (Outlook, Firefox,...)
SS-Icon vs. MS-Outlook Icon (via Flickr)
Kind regards, KNUT
I agree with above posts - I have usually opened MS Outlook, Firefox and new SS and all these icons are in similar colour .
I'd like recommend to use different default colour, or enable instance colours and let user choose default (see this thread - http://forum.altap.cz/viewtopic.php?t=2 ... c&start=30 - from those colours I would personally choose the green as default)
- Josip Tosic
The way to solve this is to start Servant Salamander at startup, so that it's the first icon in your taskbar... and never shut it down.
That way you don't have to look for the familiar icon, you just click on the first button. Seems a reasonable workaround to me...
This ist _not_ a solutionJosip Tosic wrote:The way to solve this is to start Servant Salamander at startup, so that it's the first icon in your taskbar... and never shut it down
What's about a second SS instance? Or accidentally closing and restarting SS? Or a SS crash (yes, this could happen)?
Kind regards, KNUT
Taskbar++:Can you recommend any particular tool for this?
http://www.geocities.jp/chihiro718/LZH_ ... arPP12.zip
Rogo
I use TaskArrange available from: http://users.forthnet.gr/pat/efotinis/p ... range.htmljis wrote:Can you recommend any particular tool for this?Mem wrote:Josip Tosic: Or you can hide taskbar icon and place it in systray, but this is not solution for me.
Btw, with some utilities you can change window order in taskbar using drag&drop
Will
- Josip Tosic
I know, it's a workaround.KNUT wrote:This ist _not_ a solution
It gets grouped right next to the first button, if you use taskbar grouping. Even if you don't you still have the first button sitting right there at the "pole position."What's about a second SS instance?
Once Altap guys code the queuing system, we'll never ever need to run another instance.
When this happens to me I start Servant Salamander again and minimize/restore all other apps to/from tray (I use StrokeIt with MinToTray plug-in or TaskSwitchXP, which also enables you to minimize to tray by right-clicking onto minimize button).Or accidentally closing and restarting SS? Or a SS crash (yes, this could happen)?
I know it's easier to use Taskbar++ or XNeat or a similar utility but I don't feel like using yet another utility for something that happens only once in a while.
No, you are wrong, when I am programming, I need several instances of SS opened in different folders (working folder for source files and CVS, export folder for packing and uploading to ftp etc.) and switch between them all the timeJosip Tosic wrote:Once Altap guys code the queuing system, we'll never ever need to run another instance.
The same as above - when I am working with several applications at once (database viewer and query analyzer, programming IDE, other editors, SS instances, groupware, web browser etc.), it's quite good to have them in place for easy switching (e.g. database viewer vs. IDE) on taskbar. Some people even start their applications in some order to achieve this placement in taskbar, so these utilities are really handyJosip Tosic wrote:I know it's easier to use Taskbar++ or XNeat or a similar utility but I don't feel like using yet another utility for something that happens only once in a while.
- Josip Tosic
Yes, we need tabs too.Mem wrote:No, you are wrong, when I am programming, I need several instances of SS opened in different folders (working folder for source files and CVS, export folder for packing and uploading to ftp etc.) and switch between them alltthe time
I'm not aying they're not usefull, it's just that I don't need it all that much. I tend to open half a dozen apps when I work and keep 'em open all the time. In fact, I simply hybernate my laptop with all of 'em open.The same as above - when I am working with several applications at once (database viewer and query analyzer, programming IDE, other editors, SS instances, groupware, web browser etc.), it's quite good to have them in place for easy switching (e.g. database viewer vs. IDE) on taskbar. Some people even start their applications in some order to achieve this placement in taskbar, so these utilities are really handy
Good pointJosip Tosic wrote:Yes, we need tabs too.Mem wrote:No, you are wrong, when I am programming, I need several instances of SS opened in different folders (working folder for source files and CVS, export folder for packing and uploading to ftp etc.) and switch between them all the time
I hibernate my desktop too (although 1GB takes some timeJosip Tosic wrote:I'm not saying they're not usefull, it's just that I don't need it all that much. I tend to open half a dozen apps when I work and keep 'em open all the time. In fact, I simply hybernate my laptop with all of 'em open.
But I stop this OT and only repeat - please, Altap, give me instance colours or ability to change the default icon (OK, I'll do it now with Resource Hacker
