That was the solution. I used to work with the 64 bit version. After installed and use the 32 bit version, all works fine (yet). Thank you very much!SelfMan wrote: Did you try the 32 bit version of Salamander?
Lose FTP-Connection after hours
Re: Lose FTP-Connection after hours
No problem. Still, it would be very helpfull if you could provide the Process monitor trace of the error.
Ok, what can i exactly do?
I think trying to locate this problem is wasting of time. It will be probably problem in drivers or network layer, not in Salamander.
