REQ: Desktop link in Change Drive Menu
Skrzat
Pleas add the shortcut to Desktop folder of current user in Chenge Drive menu.
Yes, but the Hot Paths are all occupiedSinaptik wrote:You can add this folder with the Hotpath function.
In Ť Configuration ť -> Ť Hot Paths ť.
I would also like to have the "Desktop" in the "Change Drive menu"!
Kind regards, KNUT
- crystalidea
We are working on a new Folders plugin which is intended for folder browsing (Desktop, Control Panel, Printers, Tasks, etc).
Folders plugin has been postponed due to the release of Servant Salamander 2.5.
Change Drive menu: structured Hot Paths are listed on our roadmap.
Screenshot of semifinished Folders plugin:
I was wanting to post the same feature request; was thinking of a solution where the menu-group was configurable like the the hot-path's.
Actually I don't understand why the documents link is there and the desktop isn't - seems to me like it was a "forgotten" feature.
/hrc
BTW. I can't figure out the attribute sort order in the list view (detail view). I know that there's 4 different pieces of information in that column, but why not just sort it as a string? It might not be easier but at least I'll understand the sort order.
/hrc
Go home Total Commander!
Please post this as a new feature request. Look at forum rules: http://forum.altap.cz/viewtopic.php?t=55hrc wrote:BTW. I can't figure out the attribute sort order in the list view (detail view). I know that there's 4 different pieces of information in that column, but why not just sort it as a string? It might not be easier but at least I'll understand the sort order.
