Lose FTP-Connection after hours
My OS is Windows 8.1 and a have never problems with ftp. But since 1 week i get after hours this message:
Error: (10093) Either the application has not called WSAStartup or WSAStartup failed
What can i do? I have only the windows firewall and anti virus program.
- fehler.jpg (30.56 KiB) Viewed 44484 times
Re: Lose FTP-Connection after hours
We are calling WSAStartup (and result is checked) when FTP Client plugin is loading, so error message is probably without sense. We don't have any idea what can cause such problem, we are sorry.
When you close and open again Salamander, does FTP plugin work again or not?
After a restart from Salamander all works fine.
OK, please try just to unload FTP plugin if it helps or not. When this FTP problem occurs: go to menu Plugins / Plugins Manager, locate FTP Client plugin, click Unload button, then close dialog and try to use FTP again, it will be loaded again and it will try to initialize WSA again. Thanks for testing!
This could mean that something is wrong with your netwok configuration. Some sysytem files may have broken.
Start CMD as a administrator (WinKey+x) and scan for corrupted system files by using sfc /scannow
Check the generated report for errors and report back please.
You might also update your network drivers. (NIC, WiFi)
I get this message:
The Log-File is very full with error-message, for example:C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
I have now update my driver for the Intel(R) Ethernet Connection I217-V. I hope this works.2015-05-21 22:31:20, Info CSI 0000076d [DIRSD OWNER WARNING] Directory [ml:520{260},l:38{19}]"\??\C:\Windows\ADFS" is not owned but specifies SDDL in component Microsoft.IdentityServer.Web.Resources, pA = PROCESSOR_ARCHITECTURE_MSIL (8), Culture = [l:10{5}]"zh-HK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
You seem to have Active Directory Federation Services installed and The permissions are not set correctly.
But I dont think thatt his would be the casue for the error mentioned.
If the new driver does not work, you can reset the winsock by following these instructions.
hasn't solved the problem. any other ideas?netsh winsock reset
Try to create a new administrative account and test it with it.
hasn't solved the problem. any other ideas?SelfMan wrote:Try to create a new administrative account and test it with it.
Can you verify the network functionality by using a different FTP client? (i.e. FileZilla)
I use flashfxp, this program works fine (even full upload is possible on a 100 mbit-download line => 10 mbyte per second; with salamander only 1,5 mbyte
my hope is that in windows 10 the program works well.
Please can you check that you have all VC++ runtimes up to date?
I have following updates installed:
It's ok?
It's ok?
- ms.gif (16.87 KiB) Viewed 43826 times
Salamander loads different libraries from v8.x,9.x, and 11.x branch. What I cant see is is the 8.x version.
On my OS, Salamander also loads msvcr80.dll v8.0.50727.6195. Although I am not sure if this is related to the problem or not.
Did you try the 32 bit version of Salamander?
BTW go to http://www.ma-config.com/ and scan your system. You will be offered a list of updated drivers which you can download there and install.
