I know you can quickly type to a file by typing the first letter of the filename, but it there an option to type to any character within a filename?
Thanks,
Derek
Quick Type to File With Any Character
Re: Quick Type to File With Any Character
Use the / key.
So /man will find "chrome.manifest".
Or /ug/c will find "plugin-container.exe" but not "plugin-hang-ui.exe" (as there is no 'c').
Thanks! Once again Altap Salamander FTW!
Just for the reference: http://www.altap.cz/salamander/help/sal ... k_qsearch/
