How to see HTC One M8 Android phone in Salamander
docfxit
Post by docfxit »
Is there a way to see the files on an HTC One M8 Android phone?
I know I can put it into Disk Drive mode to see the files on the SD card. I would like to see the files on the phone. I know the HTC Sync Manager can see the file but it is very cumbersome. It would be very nice to be able to use Salamander.
Thank you,
Docfxit
Re: How to see HTC One M8 Android phone in Salamander
docfxit
Post by docfxit »
Thank you very much.
That does let me see the files on the phone internal storage (the SD Card storage I could see without this plugin)
It does have a couple quarks that don't stop me from working with the files.
1. One is when I navigate to a folder with nothing in it displays the root folder.
Root Folder:
If I select the 100Media folder it shows me the root folder:
I expected it to show me an empty folder.
2. When I see the root folder and select the G: folder. It displays the root folder. It doesn't go into the G: folder.
The same thing happens when I select the Phone folder.
When I select the 831C folder I see the folders and files on the phone.
3. The root folder shows me [invalid] for date and time.
I am happy to successfully see the files with this plugin. I am only documenting this so
1. Other people using this plugin will know what to expect.
2. Maybe Christian Ghisler (The author of WindowsMediaAudio) might decide to fix this.
I'm using Win7 Professional sp1 32bit
Windows Media Audio 2 (MP3) 1.2.
Salamander 3.01 x86
Thank you very much for a really great program.
Docfxit
Jeffin90620
Post by Jeffin90620 »
I just updated from Salamander V2.54 to V3.04 and am having a problem listing files on my HTC EVO 4G LTE (the Sprint-specific version of the HTC One S).
With V2.54, I see the phone's internal memory (never figured out how to get to the external SD card's memory).
With V3.04, the phone lists as device D:, but with a different name (the phone's name is EVO, but Salamander lists it as "HTC Sync Manager"). When I select the phone's drive letter, the files I see in the root are not what I see if I use Explorer.
Make Files List (Ctrl+M) didn't do anything I could notice, but I was able to use the Command Line to list what I see to another drive (Access was denied when I tried listing to D:):
Why am I unable to see the actual file contents of my phone and, while we're at it, when will I be able to interact with the External SD memory?
Thanks in advance,
Jeff
Volume in drive D is HTC Sync Manager
Volume Serial Number is F28E-77FA
Directory of D:\
07/24/2012 04:24 AM 795,104 DPInst32.exe
07/24/2012 04:24 AM 930,272 DPInst64.exe
07/19/2012 03:47 AM 273,687 about.png
07/24/2012 04:24 AM 78,336 devcon32.exe
07/24/2012 04:24 AM 81,920 devcon64.exe
07/19/2012 03:47 AM 144 CLICK_HERE_HTC_Sync_Manager.url
08/09/2012 11:44 PM <DIR> WinXp
08/09/2012 11:44 PM <DIR> Vista32
08/09/2012 11:44 PM <DIR> Vista64
08/09/2012 11:44 PM <DIR> Win7_32
08/09/2012 11:44 PM <DIR> Win7_64
09/04/2012 01:45 AM <DIR> adb
09/12/2012 07:03 PM 1,798,968 HTCDriverInstaller.exe
09/12/2012 07:03 PM 1,720,120 HTCDriverUninstaller.exe
09/11/2012 02:44 AM 134 autorun.inf
09/11/2012 03:39 AM 22,789 config.dat
10/04/2012 07:30 PM 454 config.ini
10/04/2012 07:33 PM 911,160 HTC_Sync_Manager_PC.exe
10/08/2012 01:35 AM 571,904 IPTInstaller.msi
13 File(s) 7,184,992 bytes
6 Dir(s) 0 bytes free
The 5 folders have mostly these files (some have different dates and sizes between them):
Directory of D:\Win7_64
08/09/2012 11:44 PM <DIR> .
12/31/1969 04:00 PM <DIR> ..
08/30/2012 07:50 AM 62,994 androidusb.cat
08/29/2012 01:44 AM 31,258 androidusb.INF
11/02/2009 02:16 AM 33,736 androidusb.sys
08/30/2012 04:23 AM 22,604 htcrndis.cat
08/28/2012 11:42 PM 31,475 htcrndis.inf
06/09/2009 05:41 AM 1,122,664 WdfCoInstaller01007.dll
08/30/2012 07:29 AM 37,326 wpdmtphw.cat
08/28/2012 11:10 PM 35,958 WPDMTPHW.INF
8 File(s) 1,378,015 bytes
2 Dir(s) 0 bytes free
Jeffin90620 wrote:I just updated from Salamander V2.54 to V3.04 and am having a problem listing files on my HTC EVO 4G LTE (the Sprint-specific version of the HTC One S).
The files you see seem to be just some drivers and phone support software. These can be preloaded on the phone, so you can install everything without connecting to the Internet.
Do you see any differences between the accessible drives in 32-bit and in 64-bit Salamander? What option is chosen in Settings > Storage > three dots > USB connection on your phone?
Jeffin90620
The differences I see are between Salamander V2.54 and V3.04 (both 32-bit).
When I use V2.54, I see the files that are on the phone.
When I use V3.04, I see the files that I listed in the first post.
The phone's USB port is in Developer mode and has been unchanged for months.
Jeffin90620
I now understand the problem, but don't know how to fix it.
For some reason I do not understand, when I connect my phone to my computer, it comes up in Disk Drive mode when I use Salamander V2.54 and in HTC Sync Manager mode when I use V3.04 (both 32-bit and 64-bit).
I can change the setting under USB Debugging in my phone's Developer Options under Settings (for a Sprint EVO 4G LTE, a variation of the HTC ONE S), but only when the phone is connected, and there is no way to change the default setting (except to go back to using V2.54).
What has changed between V2.54 and V3.04 to cause this?
Jeff
I'm still confused about what you see. What happens when you have both Salamander versions open and plug in the phone? What disk drives do you see in each of them?
Jeffin90620
Things have changed. Now, when I connect the phone to my computer, it defaults to HTC Sync Manager mode. For both V2.54 & V3.04, this is what happens when I try to use them:
If I leave the phone in HTC Sync Manager mode, I cannot connect to the phone. It lists as a drive (G, in my case), but I cannot connect to it. Windows Explorer does not even list it as a drive.
If I change the phone to Disk Drive mode, I can see the phone's files. I am in the root (SuperSU is in the root).
I am no longer seeing the other files that seemed tied to various PC operating systems.
Jeff
Does that mean Salamander now shows the same drives and files as Explorer?
See Portable Devices plugin.
Locked
