This isn't an Altap Salamander issue, but I was just hoping for some blind help with an ARJ uncompress issue.
Obviously, feel free to delete this post if that offends you. Perhaps someone reading this likes a challenge.
Any of the ARJ files at this site are uncompressable for me: http://hair.spb.ru/games/doom2/wad/
All of the other filetypes work fine; which leads me to believe that the files are not corrupt or the victim of a 7-bit ascii transfer or MIME-type conversion issue.
After some investigating, it appears that these files:
- maybe have a malformed header?
- maybe have utf-8 characters in the header when arj doesn't support that
- ARE arj files and not some other filetype erroneously named as xxxxxxxx.arj
- Were probably created with a file-manager type tool as there is data in the text header field.
- are most likely not encrypted
I have tried many different decompressor programs on Linux, Windows, and DOS6.22 with no success. Including trying unarj, open-arj, and arj version 1.00 through 2.86.
These files are quite old by modern computer terms as they were undoubtedly created before 1997 and obviously most likely in with a cyrillic character set.
http://darbinding.sourceforge.net/specs/arj.txt might be of some assistance.
thanks in advance.
ARJ issue
Re: ARJ issue
Interesting problem
Arj.exe tells me those are not ARJ archives as well.
I have written to the author of that site - maybe he will explain it.
Re: ARJ issue
Host OS says UNIX, which is odd?
I don't seem to ever recall hearing of ARJ running on UNIX?
I do seem to recall (pretty sure it was) a .ru version of ARJ (but I'm not seeing it in my files)?
Older unarj & such I can't even run any longer (on x64 OS).
Maybe ask Robert Jung & see what he can make of them.
arjsupport@verizon.net
Re: ARJ issue
Thanks for the help guys.
I thnk the ru-based arj is what I need. hmm... I have a few more leads.
https://www.cs.cmu.edu/afs/cs/project/a ... /util/arj/ proves partial unix support in 1994(compiles with a platform-independent C compiler).
I did inquire at the official site but with no reply (before asking here).
btw, http://homepage3.nifty.com/takeda-toshi ... index.html works great. It is a ROM(as in MAME) 16-bit emulator that enables 16-bit programs to work on a 64-bit emulated ms-dos environment(cmd.exe).
msdos.exe unarj e file.arj
Re: ARJ issue
I doubt that 'ru-based arj' would help here. I tried Russian NLV arj and it did not help - and the whole idea of arj is that the first 1990 version of the program should open any files created with later versions.
And as it does not - my guess is that the files just became corrupted after all these years. The author did not answer me unfortunately.
Re: ARJ issue
Forgive the unnecessary post, but thank you for trying. You know it's a helpful forum when they try to solve other software/people's problems.
thanks again.
thanks again.
Re: ARJ issue
Well, the author of that site has answered me - no, he can't open those archives himself now, and he does not know what is wrong with them...
