I have a problem connecting via FTP to an AS400. I'm getting this message:
It was working fine with an older version of Salamander. I just installed ver. 3.04 x86 and it's not listing the members correctly.
Thanks,
Docfxit
PS: I have sent a raw log to support
FTP into AS400
Re: FTP into AS400
We have not changed this for years, so it should still work well. What was the previous version you have used and it was working in?
Do you still have that older version working? Can you confirm it still works on your FTP server?
We have received also email from you, you have sent file: IBM iSeries_i5, AS_400 (EN).str. When I start version 3.04 with default configuration and export server type IBM iSeries/i5, AS/400 (EN) from menu Options / Plugins Configuration / FTP Client / Servers (click on "IBM iSeries/i5, AS/400 (EN)", then on Other / Export to File...), I get the same file (same content). Please check your FTP Configuration / Servers if you also have the same IBM iSeries/i5, AS/400 (EN) server type (export it and compare using File Comparator plugin).
If it is another problem, I need raw listing + FTP log, send it to my email please.
Re: FTP into AS400
We have found second email from you, the listing attached is parsed well in 3.04. So I believe you have only some configuration troubles in FTP Client.
Re: FTP into AS400
When I look at the FTP servers I don't see IBM iSeries.
Thank you,
Docfxit
Thank you,
Docfxit
Re: FTP into AS400
Click Other > Import from File, select your IBM iSeries_i5, AS_400 (EN).str file.
Re: FTP into AS400
That worked great.
It was a very easy fix.
Do you have any idea why all formats weren't loaded when I installed the latest version?
It seems I am missing a few more.
Thank you very much for a really super program,
Docfxit
Docfxit
Re: FTP into AS400
No idea, strange, it should not happen. I expect you have not removed them manually (which is only "legal" possibility).
