Any Delphi plugin example available ?
barshad
Post by barshad »
Hi there,
is there any sample salamander plugin written in Delphi is available ? I know Delphi headers are available for quite long so there must be some.
Thank you,
Re: Any Delphi plugin example available ?
Delphi headers are probably outdated, you should begin with bringing it up to date. We didn't change interface much, so it should not be a lot of work. You can find differences SDK 3.01 vs SDK 2.53 and patch Delphi version.
I don't know about Delphi samples, but there are several Visual C++ samples included in Altap Salamander SDK.
Feel free to ask if you have any questions or problems.
Consider using Visual Studio Express for Windows Desktop.
